Blank Balsa Strops Pack
Wicked Edge
$36.00
Balsa has proven to be an excellent material for stropping knives. The combination of the smooth, porous surface with the slight pliability makes it a perfect choice as honing accessory. The surface is just rigid enough that it makes easy work of straightening out a rolled edge. The porous surface means that it accepts and holds stropping compounds well. Choose any of our diamond pastes, emulsions, or sprays to go with your balsa strops.
Shopify secure badge
hello
Click on the image to enlarge it.
Share this
Pin Post Plus
Similar Products
