Commercial Series Sharpener
$1,299.00
Non-US customers are responsible for Import/Duty fees.
This product is currently sold out.
PLEASE REVIEW IMPORTANT SHIPPING INFORMATION
The Commercial Series Sharpener is designed to deliver precision sharpening in commercial environments and is built for high volume use. This sharpener is modeled after the Generation 3 Pro Sharpener and features a wider angle range, a more robust frame, and an enclosed storage cabinet to meet the needs of restaurants and commercial kitchens.
- Features
- Details
- Compatibility
- Made in the USA
- Sharpens a wide assortment of knives
- Generation 3 Cam-Lock Vise - One-step knife clamping requires no additional tools to operate
- Rapid Angle Adjustment Mechanism - angle is changed on both sides of the sharpener simultaneously with the pull of a lever
- Fastest and easiest to use sharpener
- Includes Coarse 100 Grit / Medium Coarse 200 Grit Diamond Stones Pack
- Includes Medium Fine 400 Grit / Fine 600 Grit Diamond Stones Pack
- Includes Extra Fine 800 Grit / Ultra Fine 1000 Grit Diamond Stones Pack
- Can sharpen blades up to 15" long
- Angle Range: 14 to 30 Degrees (28 to 60 degrees inclusive)
- Main angle adjustment in 1 degree increments, and micro-angle adjustment in 0.05 degree increments
- Sharpener's angle markings are calibrated for knife's edge at 5/8" over top of vise
- Minimum knife height for stones to clear vise at lowest angle is 5/8" over top of vise. Low Angle Adapter (sold separately) required to reach low angles on smaller knives
- Guide Rod Length: 8"
- Product Weight: 35 LBS
- Max Clamping Width: 3/16" *Attachment for 1/4" Blades is available
The Commercial Series Sharpener is compatible with the following items:
- All Wicked Edge sharpening stones and strops
- Low Angle Adapter
- Generation 3 Jaws for 1/4" Blades
- Scissor Attachment
- Chisel Attachment
- Advanced Alignment Guide
- Safety Shields
- 10" and 12" Guide Rods
- Depth Key
The Commercial Series Sharpener is not compatible with the following items:
- Vise Key
- Hard Carrying Case
- Hard Carrying Case with Wheels and Retractable Handle
- Optional Shelf for Generation 3 Pro Sharpener
- Granite and Aluminum Bases
- Hardware Upgrade Kits
Note: Upgrade kits are not needed. The Commercial Series Sharpener includes fully upgraded hardware.
