Wicked Edge will be closed on 5.30.22 for the holiday. Contact us at support@wickededgeusa.com! Free shipping on orders over $200.00 within the contiguous United States. Expedited shipping methods are not guaranteed.
$355.00 USD
$355.00 USD
The Cam-Lock Vise with Tension Adjustment features the most sophisticated clamping technology from Wicked Edge.The jaws are free-floating and self-centering which makes them ideal for clamping fully-flat-ground blades. These jaws feature a split design which allow them to flex enough to grip distally-tapered blades. The tension adjustment allows you to add clamping tension for thinner knives.
The Cam-Lock Vise is taller than other Wicked Edge Vises, so the 10" Guide Rods ar. . .
Read More
The Cam-Lock Vise is taller than other Wicked Edge Vises, so the 10" Guide Rods are included with this upgrade kit.
The Ball-Joints have broached, threaded studs which fit a 1/8" Allen Wrench. Use an Allen Wrench to thread the Ball-Joints closer to or farther from the sharpener's Vise to make micro-angle adjustments. Then use the Knurled Jam-Nut to lock the angle in place.
The 11" Degree Bar is calibrated for the height of the Cam-Lock Vise. It has an angle range to 13-35 degrees per side (26-70 degrees inclusive)
Included parts:
