Generation 3 Jaws for 1/16" Blades
Please fill in the form below if you'd like to be notified when it becomes available.
Out of stock
Shopify secure badge
The Generation 3 Jaws for 1/16" Blades are an attachment for the Generation 3 Pro Sharpener and Generation 3 Vise that open smaller than the standard jaws which give them more clamping power on 1/16" blades. (Please note the jaws will not clamp knives thicker then 3/32" when this attachment is installed).
Note: If you have a 2017 Generation 3 Pro sharpener this product is not necessary because your sharpener is already equipped with tension adjustment.
Description
Description
Click on the image to enlarge it.
Share this
Pin Post Plus
Similar Products
