WE130UP3
Not Available
$380.00
Not Currently Available
Non-US customers are responsible for Import/Duty fees.
This product is currently sold out.
The Cam-Lock Vise with Tension Adjustment features the most sophisticated clamping technology from Wicked Edge. The jaws are free-floating and self-centering which make them ideal for clamping fully-flat-ground blades. These jaws feature a split design which allow them to flex enough to grip distally-tapered blades. The tension adjustment allows you to add clamping tension for thinner knives. The Vise is fully enclosed to prevent diamond particles or metal shavings from damaging the cam.
The Cam-Lock Vise is taller than other Wicked Edge Vises, so the 10" Guide Rods are included with this upgrade kit.
The Ball-Joints have broached, threaded studs which fit a 1/8" Allen Wrench. Use an Allen Wrench to thread the Ball-Joints closer to or farther from the sharpener's Vise to make micro-angle adjustments. Then use the Knurled Jam-Nut to lock the angle in place.
The 11.5" Degree Bar will extend the angle range to 13-35 degrees per side (26-70 degrees inclusive)
Included parts:
  • Cam-Lock Vise with Tension Adjustment
  • Ball-Joint with Broached Stud (2ea)
  • 2017 Mini L-Bracket (2ea)
  • 10" Guide Rod (2ea)
  • 11.5" Degree Bar
  • Knurled Jam-Nut (2ea)
  • 10-32 7/8" Socket Cap Screw
Customer Reviews
Based on 1 review Write a review
