PaperStone Base
$65.00
Click here to see Holiday Shipping Deadlines. Note: International Customers are responsible for Import/Duty fees.
Shopify secure badge
This product is currently sold out.
Please fill in the form below if you'd like to be notified when it becomes available.
Description
PaperStone® is a sustainable composite material made from 100% post-consumer recycled paper PetroFree™ phenolic resins and natural pigments. As PaperStone® ages it will assume a pleasing lustrous seasoned appearance that is an inherent characteristic of the material.
This base has been pre-drilled to accept the Wicked Edge Precision Sharpener WE100, WE120, and WE130. Four rubber feet are included.
Technical Specifications
  • Weight: 7.5 LBS
  • Dimensions: 12"x10"x1.25"
With dimensions of 12" x 10" x 1.25", the Wicked Edge Base comes with pre-drilled holes for mounting the WE100, WE120, or WE130 Precision Sharpeners. This base is made from a material called PaperStoneTM. If you are familiar with MicartaTM, you will find it very similar. It is dense and tough with a beautiful luster.
COLORS MAY VARY based on supply
Customer Reviews
Based on 1 review Write a review
Similar Products
