Pro-Pack I with Quartz Stone Base and Hard Carrying Case
Sale price$749.00 Regular price$849.00
Save $100.00
Available while supplies last!
The Pro-Pack I is designed around our WE100 Precision Sharpener to create super tough, durable, hard-working edges; perfect for your everyday carries and hunting or bushcraft knives.
Features:
  • The 1000 grit Diamond Stones ensure a working edge that’s capable of taking on any task.
  • 5/3.5 Micron Diamond Strops Pack helps to create a longer-lasting edge with a beautiful shine.
  • A beautiful quartz stone base that provides a solid platform.
  • The Nanuk 940 is a large, waterproof, impact-resistant case with custom foam inserts.
  • The Standard Vise allows you to clamp thicker, outdoor blades with ease.
  • Made in the USA.
Specs:
  • Angle Range: 15-30 degrees per side (30-60 degrees inclusive)
  • Angle adjustment in 1-degree increments
  • Angle markings are calibrated for the knife's edge to sit at 5/8" above the top of the vise
  • Able to clamp blades up to 1/4” thick
    • Longer screws may be used to enable the clamping of thicker blades
  • Guide Rods length: 8"
  • Product Weight: 25 LBS
Includes:
  • Precision Sharpener WE100
  • 100/200 Grit Diamond Stones Pack (2 ea)
  • 400/600 Grit Diamond Stones Pack (2 ea)
  • 800/1000 Grit Diamond Stones Pack (2 ea)
  • 5/3.5 Micron Diamond and Leather Strops Pack
  • Vise Key
  • Depth Key
  • Standard Alignment Guide
  • Shims Pack
  • Knife Brace
  • Quartz Stone Base
  • Nanuk 940 Hard Carrying Case
The Pro-Pack I is compatible with the following items:
  • All Wicked Edge sharpening stones and strops
  • Hardware Upgrade Kits
  • Low Angle Adapter
  • Scissor Attachment
  • Chisel Attachment
  • Safety Shields
  • 10", 12", 14" and 15" Guide Rods
The Pro-Pack I is not compatible with the following items:
  • Gen3 V2 Jaws for 1/4" Blades
  • Gen3 V2 Jaws for 3/16" Blades
  •  DualCam© Vise Jaws for 1/4" Blades
  • 13” Guide Rods for WE60 Series Sharpeners
  • Aluminum Base for WE60 Series Sharpeners
