Aluminum Base
Wicked Edge
$70.00
Shopify secure badge
hello
Description
This new base is made from solid Aluminum. It's designed to keep the Wicked Edge sharpener perfectly steady while in use. The Aluminum Base is finished with black powder-coating. It has four rubber feet in the corners which provide stability, and protect the surface it rests on. The holes in the base are countersunk, and it attaches to the sharpener with 2 x 1" 10-32 Socket Cap Screw.
This base has been pre-drilled to accept the Wicked Edge Precision Sharpener WE100, WE120, and WE130.
Specs:
  • Dimensions: 11" x 8" x 1"
  • Weight: 8.1 lbs
  • Finish: Black
  • Socket Cap Screws and rubber feet are included
Click on the image to enlarge it.
Share this
Pin Post Plus
Similar Products
