Field and Sport
$399.00
In stock
Customer Reviews
Based on 5 reviews Write a review
Shopify secure badge
The Field & Sport Knife Sharpener is the portable version of the Precision Sharpener - WE120. It features a lightweight carrying case and easily clamps to any firm surface with the included C-Clamp. There is a simple, easy to use angle adjustment with 1° increments ranging from 13°-35°, ball joint pivots and micro angle adjustments.
Description
Features:
  • Guide Rod pivots: Ball-Joint/L-bracket
  • Angle Range: 13-35 degrees
  • Angle Setting: Manual, independent angle adjustment on both sides of the sharpener
  • Main angle Adjustment: 1 degree increments
  • Micro Adjustment: 0.05 degree increments
  • Clamping System: Parallel jaws with stainless steel inserts, manually operated with an Allen Wrench
  • Knife Alignment: Built-on Alignment Guide
  • Blade Depth Regulation: Standard Wicked Edge Depth Key with two settings for height adjustment
  • Guide Rod Length: 8 inches
  • Max Clamping Width: 3/8"
  • Base: C-clamp
Technical Specs
  • 6061 T6 Aluminum
  • Stainless Steel
  • Weight: 4.3 LBS
  • Dimensions: 8"w x 2.5"d x 6.5"h
Abrasives:
  • Coarse 100 Grit / Medium Coarse 200 Grit Diamond Stones (2 ea)
  • Medium 400 Grit / Fine 600 Grit Diamond Stones (2 ea)
          • Base: C-clamp
          • 6061 T6 Aluminum
          • Stainless Steel
          • Weight: 4.3 LBS
                  Description
                  Features:
                  • Base: C-clamp
                  Technical Specs
                  • 6061 T6 Aluminum
                  • Stainless Steel
                  • Weight: 4.3 LBS
                  Abrasives:
                          Click on the image to enlarge it.
                          Share this
                          Pin Post Plus
                          Similar Products
