Wicked Edge GO Deluxe Holiday Special
$344.00
In stock
  • Wicked Edge GO Deluxe Holiday Special
Shopify secure badge
The Wicked Edge GO Deluxe Holiday Special is available for a limited time only during the holiday season.
We’ve combined our popular Wicked Edge GO knife sharpener with our Deluxe Bag and the essential abrasives needed to create a simple, lightweight sharpening package that will let anyone put a Wicked Edge on their knives. Made in the USA from quality materials that are made to last, the Wicked Edge GO knife sharpener is easy to use and small enough to store in a kitchen drawer or closet. The included Deluxe Bag stows the sharpener, stones and strops neatly and is always ready to head into the field or be mounted to a kitchen counter before the holiday feast.
Easy to use for beginners and experts alike, the Wicked Edge GO maintains an angle of your choice, so you can create super sharp, perfect edges on every knife. We've bundled a set of 800/1000 Grit Diamond Stones and 5/3.5 Micron Diamond Leather Strops with this package, so you’ll be able to put a truly wicked edge on all your knives at a great price!
Description
 Features
  • Precision Angle Control – Creates razor sharp edges that are easy to maintain
  • Holds your desired angle while you sharpen
  • Sharpens a wide assortment of knives
  • Sharpening angles and knife mounting are perfectly repeatable, so touch-ups are fast and gentle on the knife
  • Lightweight, portable and compact - Easy to store in small spaces
  • Deluxe storage bag for organized storage of sharpener and included abrasives
  • Easy C-Clamp mounting to any hard surface
  • Holes in platform for permanent or semi-permanent mounting
  • Can be set up for left or right hand use
  • Made in the USA and built to last!
 Product Details
  • Angle Range: 15-30 degrees per side, which will accommodate the vast majority of knives
  • Angles are set manually on each side of the sharpener, and can be set to achieve perfect symmetry or off-set to sharpen asymmetrical grinds.
  • Angles settings are marked in 1 degree increments.
  • The clamping mechanism is a vise with two parallel jaws, which is operated with an Allen wrench.
  • The vise can accommodate blades up to 3/8" thick, and can clamp thicker blades with longer screws (not included)
  • 8 inch guide rods can sharpen blades up to 15" long.
  • Total weight: 6.7 LBS
  • Dimensions: 12"w x 4"d x 4"h when stored in bag
  • Sharpener components are made from 6061 T6 Aluminum and Stainless Steel
  • Abrasive holders (handles) are made from ABS plastic
Included Abrasives and Accessories
  • Medium Coarse 200 Grit / Fine 600 Grit Diamond Stones (2 each)
  • Extra Fine 800 Grit / Ultra Fine 1000 Grit Diamond Stones (2 each)
  • 5/3.5 Micron Diamond and Leather Strops Pack
  • Depth Key
  • Mounting C-Clamp
  • Deluxe Bag which holds a total of 3 sets of abrasives
  • Marker
  • Depth Key
  • Mounting C-Clamp
  • Marker
Description
 Features
 Product Details
  • Depth Key
  • Mounting C-Clamp
  • Marker
Click on the image to enlarge it.
Share this
Pin Post Plus
Similar Products
