Wicked Edge GO Deluxe Pack
$399.00
Non-US customers are responsible for Import/Duty fees.
This product is currently sold out.
Please fill in the form below if you'd like to be notified when it becomes available.
We’ve combined our popular Wicked Edge GO knife sharpener with our Deluxe Bag and the essential abrasives needed to create a simple, lightweight sharpening package that will let anyone put a Wicked Edge on their knives. Made in the USA from quality materials that are made to last, the Wicked Edge GO knife sharpener is easy to use and small enough to store in a kitchen drawer or closet. The included Deluxe Bag stows the sharpener, stones and strops neatly and is always ready to head into the field or be mounted to a kitchen counter before the holiday feast.
Easy to use for beginners and experts alike, the Wicked Edge GO maintains an angle of your choice, so you can create super sharp, perfect edges on every knife. We've bundled a set of 800/1000 Grit Diamond Stones and 5/3.5 Micron Diamond Leather Strops with this package, so you’ll be able to put a truly wicked edge on all your knives at a great price!
  • Features
  • Details
  • Includes
  • Compatibility
    • Made in the USA
    • Precision Angle Control – Creates razor sharp edges that are easy to maintain
    • Holds your desired angle while you sharpen
    • Sharpens a wide assortment of knives
    • Sharpening angles and knife mounting are perfectly repeatable, so touch-ups are fast and gentle on the knife
    • Lightweight, portable and compact - Easy to store in small spaces
    • Deluxe storage bag for organized storage of sharpener and included abrasives
    • Includes Medium Coarse 200 Grit / Fine 600 Grit Diamond Stones Pack
    • Includes Extra Fine 800 Grit / Ultra Fine 1000 Grit Diamond Stones Pack
    • 5/3.5 Micron Diamond and Leather Strops Pack
    • Easy C-Clamp mounting to any hard surface
    • Holes in platform for permanent or semi-permanent mounting
    • Can be set up for left or right hand use
    • Can sharpen blades up to 15” long
    • Can clamp blades up to 1/4” thick with included vise screws (longer screws may be used to enable clamping of even thicker blades)
    • Angle range: 15-30 degrees per side (30-60 degrees inclusive)
    • Angle adjustment in 1 degree increments
    • Sharpener's angle markings are calibrated for knife's edge at 5/8" over top of vise
    • Minimum knife height for stones to clear vise at lowest angle is 5/8" over top of vise. Low Angle Adapter (sold separately) required to reach low angles on smaller knives
    • Guide rod length: 8”
    • Product weight: 4.2 LBS
    • Packaged dimensions: 14” x 4.5” x 4”
    • Medium Coarse 200 Grit / Fine 600 Grit Diamond Stones (2 each)
    • Extra Fine 800 Grit / Ultra Fine 1000 Grit Diamond Stones (2 each)
    • Depth Key
    • Mounting C-Clamp
    • Deluxe Bag which holds a total of 3 sets of abrasives
    • Marker
  • The Wicked Edge GO is compatible with the following items:
    • All Wicked Edge sharpening stones and strops
    • Low Angle Adapter
    • Scissor Attachment
    • Chisel Attachment
    • Advanced Alignment Guide
    • Safety Shields
    • 10" and 12" Guide Rods
    The GO is not compatible with the following items:
    • Hardware Upgrade Kits, including the Generation 3 Cam-Lock Vise
    • Hard Carrying Cases
    • Granite, Aluminum, and Paperstone Bases
