Generation 3 Pro (Discontinued)
The Generation 3 Pro was discontinued in 2023.
You can find our new flagship model, the Generation 4 Pro, here.
The Generation 3 Pro was designed for high-volume users and knife enthusiasts. For 7 years, this was our flagship model making sharpening easier, faster, and more convenient.
Featured:
- One-step angle adjustment simultaneously adjusted the sharpening angle on both sides of the blade, making for a faster and simpler experience
- Cam-Lock Vise Jaw design allowed for quick, easy, and secure clamping of a wide variety of blades, such as kitchen, outdoor, and pocket knives.
- The Cam-Lock Vise included a tension adjustment to accommodate different blade thicknesses.
- Self-centering jaw, which made for a more consistent, symmetrical bevel resulting in a great-looking and high-performing edge
- Made in the USA
Included:
- 100/200 Grit Diamond Stones Pack (2 ea)
- 400/600 Grit Diamond Stones Pack (2 ea)
- 800/1000 Grit Diamond Stones Pack (2 ea)
- 8” Guide Rods
- Depth Key
- Standard Alignment Guide
- Shims Pack
- Nanuk 930 hard case with custom foam inserts
Specs:
- Can sharpen blades up to 15" long
- Angle Range: 13.5 to 27.5 degrees per side (27 to 55 degrees inclusive)
- Angle adjustment in 0.05-degree increments
- Angle markings are calibrated for the knife's edge to sit at 5/8" above the top of the vise
- Able to clamp blades up to 3/16” thick
- Guide Rod Length: 8"
- Product Weight: 26 LBS
The Generation 3 Pro is compatible with the following items:
- All Wicked Edge sharpening stones and strops
- Low Angle Adapter
- Gen3 V2 Jaws for 1/4" Blades
- Scissor Attachment
- Chisel Attachment
- Optional Shelf for Generation 3 Pro Sharpener
- Generation 3 Pro: Shelf Conversion Kit
- Advanced Alignment Guide
- Safety Shields
- 10", 12", 14" and 15" Guide Rods
- Depth Key
The Generation 3 Pro is not compatible with the following items:
- DualCam© Vise Jaws for 1/4" Blades
- 13” Guide Rods for WE60 Series Sharpeners
- Aluminum Base for WE60 Series Sharpeners
- Hard Carrying Case for Precision Sharpener, Pro-Pack I, and Pro-Pack II
- Granite and Aluminum Bases for WE100 Series Sharpeners
- Hardware Upgrade Kits
- This model is fully upgraded
Sale price$0.00
Regular price (/)
This product is rated 4.9 of 5.0 stars.
It has received 19 reviews.
