Wicked Edge GO - WE60
Sale price$275.00
Base: No Base
Case: No Case
The Wicked Edge GO - WE60 is the most versatile sharpener we offer, allowing newbies and sharpening experts alike to put a Wicked Edge on their blades. The GO is a durable, tough working sharpener in a small, portable size.
Features:
  • Redesigned Standard Vise allows easier clamping on fully flat ground and distally tapered blade styles frequently found on kitchen and pocket knives.
  • Lightweight and compact for easy home storage or travel.
  • Can be secured to any hard, flat surface with the included C-clamp or directly mounted to a work surface through the predrilled holes in the base.
  • Made in the USA.
Includes:
  • Premium Monocrystalline 200/600 Grit Diamond Stone Pack (2 ea)
  • Type 2 Anodized Aluminum Blue Base and Standard Vise
  • 8.75" Stainless Steel Guide Rods
  • C-Clamp
  • Depth Key
  • Vise Key
  • Standard Alignment Guide
  • Guide Rod Shields
  • Shims Pack
  • Practice Knife
    • The knife shown in the images is not included
  • Limited Lifetime Warranty
Specs:
  • Angle Range: 13-31 degrees per side (26-62 degrees inclusive)
  • Angle Markings in 1-degree increments
  • Angle markings are calibrated for the knife's edge to sit at 5/8" above the top of the vise
  • Able to clamp blades up to 1/4” thick
    • 1/4-20 x 1/2" and 1/4-20 x 1" Screws included for different blade thicknesses
  • Guide Rod length: 8.75"
  • Product weight: 3.6 LBS
The WE60 is compatible with the following items:
  • All Wicked Edge sharpening stones and strops
  • 13" Guide Rods for WE60 Series Sharpeners
  • Low Angle Adapter
  • Scissor Attachment
  • Chisel Attachment
  • Advanced Alignment Guide
  • Safety Shields
  • Aluminum Base for WE60 Series Sharpeners
  • Hard Carrying Case for WE60-Series Sharpener
The WE60 is not compatible with the following items:
  • 10", 12", and 15" Guide Rods
  • Gen3 V2 Jaws for 1/4" Blades
  • Gen3 V2 Jaws for 3/16" Blades
  • DualCam© Vise Jaws for 1/4" Blades
  • Low Angle Kit
  • Blade Stabilizer
