Wicked Edge GO – WE60 Knife Sharpener Instructions
The Wicked Edge GO – WE60 is our most portable guided angle sharpener, offering professional-grade results in a compact design. This page will walk you through the setup process, safe usage tips, and sharpening techniques so you can get the most from your WE60. Whether you’re new to precision sharpening or a seasoned expert, these video tutorials will help you sharpen like a pro.
Setting Up Your Wicked Edge GO – WE60
Getting Started: Learn how to assemble and mount your WE60 sharpener correctly to ensure stability and accuracy.
Watch the WE60 Setup Video
Sharpening Basics and Safety
How to Sharpen Safely: Get key safety tips for hand placement, motion control, and working with abrasive stones.
Watch the Safety Guide
Using the Vise
Mounting Your Knife: Understand how to clamp your knife securely in the Vise for consistent results every time.
Watch the Vise Tutorial
Finding the Right Angle
Angle Setting and Sweet Spot: Learn how to identify the optimal sharpening angle and mount position for your blade.
Watch the Angle and Sweet Spot Video
Sharpening Technique
Creating a Burr: Discover how to confirm you're reaching the apex by forming and detecting a burr.
Watch the Burr Tutorial -
Sharpening on the WE60: Follow a full walkthrough of the sharpening process using the WE60’s guided angle system.
Watch the Sharpening Tutorial
Touch-Ups and Maintenance
Touching Up Your Knife: Learn how to quickly maintain your edge without starting the full sharpening process.
Watch the Touch-Up Video
Learn more about our Wicked Edge precision sharpeners here.
