Venture™ WE20 Kits
5-Year Warranty | 60 Day No Hassle Returns | Made in USA
Sale price$58.00
Venture WE20 kit: Restore
Restore Pack
Built for damaged, neglected, or extremely dull edges. The Restore Pack focuses on aggressive material removal to bring worn blades back to life. The dual-sided 100/200 grit diamond stone allows you to quickly reprofile chipped edges, correct uneven bevels, and reset edge geometry before moving into refinement.
Includes:
Wicked Edge Venture Sharpener (WE20)
— 500-grit Diamond Stone
— Ceramic Hone
— 20° Angle Guide
— Leather Strop
— 100/200 Grit Diamond Stone
Best for: edge repair, reprofiling, and heavily worn blades.
Restore Pack
The Restore Pack focuses on aggressive material removal to bring worn blades back to life. The dual-sided 100/200 grit diamond stone allows you to quickly reprofile chipped edges, correct uneven bevels, and reset edge geometry before moving into refinement. Ideal for knives that need real work, not just a touch-up.
Includes:
  • Wicked Edge Venture Sharpener (WE20)
    Ceramic Hone
    20° Angle Guide
    Leather Strop
  • 100/200 Grit Diamond Stone
Refine Pack
Designed to clean up and sharpen an established edge.
The Refine Pack is built for users who already have solid edge geometry and want smoother, more consistent bevels. The 800/1000 grit diamond stone refines scratch patterns and improves cutting performance while maintaining control and precision.
Includes:
    -500-grit Diamond Stone
    -Ceramic Hone
    -20° Angle Guide
    -Leather Strop
  • 800/1000 Grit Diamond Stone
Best for: routine sharpening, edge maintenance, and improving cutting efficiency.
Refine+ Pack
For those who want sharper, cleaner, more refined edges.
The Refine+ Pack expands your sharpening capability by pairing 800/1000 grit refinement with 1500/2200 grit finishing. This progression delivers noticeably smoother edges, reduced friction, and improved push-cut performance without chasing a full mirror polish.
Includes:
    -Ceramic Hone
    -20° Angle Guide
    -Leather Strop
  • 1500/2200 Grit Diamond Stone
Best for: high-performance edges, smoother finishes, and advanced refinement.
Ultimate Pack
A complete sharpening system with full control over edge geometry.
The Ultimate Pack combines aggressive reprofiling, refined progression, and precise angle control into one comprehensive setup. From repairing damaged blades with 100/200 grit, through refinement and finishing with 800/1000 and 1500/2200, this pack gives you full command of the sharpening process. Multiple angle guides allow you to tailor edges for durability, slicing efficiency, or fine cutting tasks.
Includes:
    -Ceramic Hone
    -20° Angle Guide
    -Leather Strop
  • 15°, 17°, and 25° Angle Guides
Best for: complete edge control, advanced users, and maximum versatility.
