How to Sharpen Straight Razors on a Wicked Edge Sharpener
Sharpening straight razors with a Wicked Edge precision knife sharpener is not only possible—it’s surprisingly effective when done correctly. While straight razors require a very fine edge and delicate technique, our guided angle sharpening system makes it easy to get a razor-sharp finish every time.
Check out this video walkthrough for a visual guide to the process: How to Hone and Strop a Straight Razor on the Wicked Edge
Recommended Abrasive Progression for Straight Razors
When working with straight razors, it's important to stay on the finer end of the abrasive spectrum to avoid removing too much steel and to maintain the smoothest possible edge. Below is the progression we recommend for optimal results:
Start with 1500/2200 Grit Diamond Stones – Avoid going any coarser. These stones provide a precise and controlled refinement of the edge.
 Shop 1500/2200 Grit Diamond Stones
6 Micron Lapping Films – These films start the polishing process and further refine the bevel.
 Shop 6 Micron Diamond Lapping Films
 Alternative: Use our 3000 Grit Diamond Stones if you prefer stones over films.
 Shop 3000 Grit Diamond Stones
3 Micron Lapping Films – Continue polishing with an even finer abrasive for mirror-like results.
 Shop 3 Micron Diamond Lapping Films
Stropping for a Razor Finish
Once the edge is finely polished, stropping is the final step that brings out the true razor edge. Use our emulsion-loaded leather strops in two steps:
4/2 Micron Diamond Emulsion and Leather Strops
 Shop 4/2 Micron Emulsion Leather Strops
1/0.5 Micron Diamond Emulsion and Leather Strops
 Shop 1/0.5 Micron Emulsion Leather Strops
With this methodical progression and careful attention to pressure, your straight razor will be able to deliver a clean, comfortable shave—every time.
Learn more about our Wicked Edge precision sharpeners here.
