How to Use the Wicked Edge Generation 4 Pro Knife Sharpener
The Wicked Edge Generation 4 Pro is our most advanced guided angle sharpener, built for unmatched precision and repeatability. This guide will walk you through the essential steps to get started using your Gen 4 Pro, from setup and vise operation to sharpening technique and touch-ups.
Getting Started with Your Generation 4 Pro
The Generation 4 Pro includes everything you need to begin sharpening right out of the box. If you're setting it up for the first time, watch this overview video:
Using the Micro-Angle Adjust (Optional)
The Micro-Angle Adjust feature is available on some Gen 4 Pro models. It allows you to fine-tune your sharpening angle with incredible precision—perfect for high-end steels or repeatable maintenance sharpening.
Mounting the Knife and Vise Operation
The Cam-Lock Vise system makes it easy to secure your knife quickly and firmly. Be sure to choose the correct starting position for your blade to find the "sweet spot"—the most consistent angle across the entire edge.
Sharpening with Diamond Stones
Wicked Edge diamond stones are the foundation of your grit progression. Learn the correct sharpening motion and how to maintain even pressure for optimal results:
Finding Your Angle and Sweet Spot
Correct angle selection and positioning are critical for achieving a consistent edge. Watch this video to master the marker method and find the perfect sharpening angle:
Sharpening Tips and Techniques
- Wicked Edge Repeatability Tools – Use tools like the Alignment Guide and Depth Key to maintain consistent results.
- Creating a Burr – Learn how to detect and raise a burr for confirmation that you’ve fully apexed the edge.
- Sharpening a Knife – See the full sharpening process in action on the Gen 4 Pro.
- Touching Up a Blade – Quick maintenance tips to restore your edge.
- Sharpening the Practice Knife – Use the included practice knife to get comfortable with the system.
Whether you're new to guided angle sharpening or upgrading from a previous model, the Generation 4 Pro delivers unmatched control and repeatability.
Learn more about our Wicked Edge precision sharpeners here.
