WE60 GO Pro Pack I
Precision Knife Sharpener
Sale price$510.00
Precision Sharpening. Anywhere.
Wicked Edge GO dual-sided knife sharpener in grass at close-up from side angle.
Experience professional-grade sharpening with the Wicked Edge GO - WE60 Precision Knife Sharpener​—a compact, portable solution designed for both beginners and seasoned enthusiasts. Whether at home, in the field, or on the go, this sharpener delivers consistent, razor-sharp edges with ease.
Wicked Edge GO dual-sided precision knife sharpener in kitchen setting at close-up from front angle.
Key Features:
Redesigned Standard Vise: Easily clamps fully flat ground and distally tapered blades, common in kitchen and pocket knives.
Adjustable Angle Range: Sharpen at angles from 13° to 31° per side (26°–62° inclusive) in 1° increments, ensuring precise edge customization.
Premium Diamond Stones: Includes 200/600 grit monocrystalline diamond stones for efficient sharpening.
Compact & Lightweight: Weighs just 3.6 lbs, making it ideal for travel and easy storage.
Made in the USA: Crafted with high-quality materials for durability and longevity.​
Specifications:
Blade Length Capacity: Up to 15"
Blade Thickness Capacity: Up to 1/4" (longer screws available for thicker blades)
Angle Markings: Calibrated for the knife's edge to sit at 5/8" above the top of the vise
Guide Rod Length: 8.75"
Product Weight: 3.6 lbs
What's Included:
(2) 800/1000 Grit Diamond Stones
(2) Leather Strops with 5/3.5 micron stropping paste
C-Clamp
Depth Key
Vise Key
Standard Alignment Guide
Guide Rod Shields
Shims Pack
Practice Knife (Note: The knife shown in images is not included)
Limited Lifetime Warranty
Depth Key
Advanced Alignment Guide
Shims Pack
Practice Knife
Lifetime Warranty
Optional Micro-Adjusts and Storage Shelf​
Compatibility:
13" Guide Rods for WE60 Series Sharpeners
Low Angle Adapter
Scissor Attachment
Chisel Attachment
Safety Shields
Aluminum Base for WE60 Series Sharpeners
Hard Carrying Case for WE60-Series Sharpener​
60 Series Low Angle & Small Knife Kit with WELA2 adapter in studio setting at close-up view from front angle.60 Series Low Angle & Small Knife Kit extension in studio setting at close-up zoom from front angle.
