What Materials Does Wicked Edge Use in Their Products?
At Wicked Edge, we carefully select high-performance materials to ensure our precision knife sharpeners, accessories, and abrasives deliver professional-grade results and long-lasting durability. This article breaks down the key materials used across our sharpeners, handles, and abrasives, so you can better understand the quality behind every Wicked Edge product.
Materials in Wicked Edge Sharpeners, Attachments, and Adapters
Wicked Edge sharpeners are engineered for stability, smooth operation, and long-term reliability. Here’s what we use:
- 6061-T6 Aluminum: This aircraft-grade aluminum provides a strong, lightweight foundation for most of our sharpeners and adapter components.
- Stainless Steel: Used for components that require additional strength, corrosion resistance, or wear durability.
- Delrin: On 60 Series models, we use this low-friction, high-wear polymer for specific non-load-bearing parts. It reduces drag and improves the feel of movement during sharpening.
- Type III Anodizing: Key components—such as jaws, vises, and bases—are hard anodized for enhanced scratch resistance and surface hardness.
What Are Wicked Edge Handles Made Of?
Our handle construction balances strength with ergonomic performance:
- Welded Construction: All abrasive handles are sonic welded for secure, consistent assembly.
- Diamond Stones: Wicked Edge Diamond Stones use electroplated monocrystalline diamonds bonded to aluminum platens. Monocrystalline diamonds are known for their hardness and durability, making them ideal for sharpening steel blades.
Stropping Compounds: What’s Inside?
All Wicked Edge stropping compounds—whether paste, emulsion, or spray—share the same core ingredients:
- Water-Based Formulas: Environmentally friendly and easy to clean.
- Polycrystalline Diamonds: These diamond particles offer multiple cutting edges per crystal, providing fast, consistent stropping results.
What Are Wicked Edge Lapping Films Made Of?
Our high-performance Lapping Films are ideal for achieving a mirror polish:
- Mylar Substrate: Flexible and durable backing that conforms to the blade’s surface.
- Monocrystalline Diamonds: These films are impregnated with uniform diamond particles for even, repeatable results at ultra-fine grits.
From the core of our sharpeners to the abrasives you rely on for a razor-sharp finish, every material we choose is designed for performance, precision, and longevity.
