60 Series Precision Knife Sharpeners
Sale price$299.00
Sharpener Model: GO-WE60 (Standard Vise & Standard Angle Slides)
Aluminum Base: Without Aluminum Base
The 60 Series Precision Knife Sharpeners provide a portable sharpening experience balanced with durability and versatility. With a range of options to build the perfect sharpener for you, the 60 Series is perfect for sharpening greenhorns and experts alike.
Features:
  • Premium 200/600 Grit Diamond Stones provide an excellent working edge for all of your pocket EDCs
  • It can be secured to any hard, flat surface with the included C-clamp, the optional Aluminum Base, or directly mounted to a work surface through the predrilled holes in the base
  • Lightweight and compact for easy home storage or travel
  • Customizable features allow you the freedom to build the sharpener that fits your needs
  • Designed, manufactured, and assembled in the USA
Vise Styles:
  • The Standard Vise (WE60) offers you the most versatile clamping option to secure any blade in your collection safely, no matter how thin or thick your blade is.
  • The DualCam Vise© (WE64 & WE66) provides the fastest clamping available. With up to 1,400 pounds of clamping force, this vise allows for effortless, highly efficient clamping so you can breeze through your sharpening sessions.
Angle Settings:
  • The Standard Angle Slide (WE60 & WE64) lets you quickly set your angle, secure the setting, and get to sharpening. Perfect for those who value speed and want to get their knife back to sharp as fast as possible.
  • The Micro Angle-Drive© (WE66) was designed for those who are chasing perfection. With the ability to make minute changes to hone in on your precise angle, this angle setting lets you match perfectly with your blade's bevels.
Includes:
  • Premium 200/600 Grit Diamond Stone Pack (2 ea)
  • Type 2 Anodized Aluminum Base and Vise
  • 8.75" Stainless Steel Guide Rods
  • C-Clamp
  • Depth Key (DualCam© Vise)
  • Depth Stop in 3 sizes (Standard Vise)
  • Standard Alignment Guide
  • Guide Rod Shields
  • Shims Pack
  • Practice Knife (the knife shown in the images is not included)
  • Full YouTube instructional playlist
  • Lifetime Warranty
Specs:
  • Angle Range: 13-31 degrees per side (26-62 degrees inclusive)
  • Angle Markings in 1-degree increments
  • Angle markings are calibrated for the knife's edge to sit at 5/8" above the top of the vise
  • DualCam Vise: Able to clamp blades up to 3/16” thick
  • Standard Vise: Able to clamp blades up to 1/4" thick
  • Guide Rod length: 8.75"
  • Product weight: 3.6 LBS to 4.15 LBS depending on options
Compatibility:
  • All Wicked Edge sharpening stones and strops
  • 13" Guide Rods for WE60 Series Sharpeners
  • Low Angle & Small Knife Adapter
  • 60 Series Low Angle & Small Knife Kit
  • Scissor Attachment
  • Chisel Attachment
  • Aluminum Base
  • Cobalt-WE64 and Obsidian-WE66 only:
    • DualCam© Vise Jaws for 1/4" Blades
    • Blade Stabilizer
    • Advanced Alignment Guide
    • Depth Key
Customer Reviews
Based on 24 reviews
79%
(19)
17%
(4)
0%
(0)
4%
(1)
0%
(0)
J
James
Very poor. Not like the other one I’ve had for years.
D
Derrick J.
Edge Pro convert
After years of struggling with the Edge pro, I decided to make the investment on the WE64. The sharpener does everything that it advertises and more. From kitchen knives to fix blades to folders this sharpener has the ability to be very intuitive and also efficient. Of all the sharpening systems I’ve ever used. This one is the most consistent and easy to use. It secures to the bench, clamps the knife, does not make a huge mess, has great customer support and video help. So happy to have found wicked Edge.
K
Kyle A.
Works great
R
Rodney B.
So far a HaPpy Camper
Started with the practice blade X2s, then I sharpen a couple Made In, 4" then a 6" kitchen knives.
After those I sharpen a 6" Calphalon.
Then I sharpen my 4" Japanese Damascus, then a 8" Japanese Kenetsune.
Setting up the angle is the most challenging to me. Example the Kenetune is sharpened at 17 degree, To get the 17, had to put knife holder at 15 degrees.
To me this is a lot better then the wet stone method.
Thank you Wicked Edge.
L
Lucian D.
Very happy with this purchase. It is the 2nd system I have bought. Keep 1 system in my hunting cabin, and this system at home.
