How to Sharpen Broadheads on a Wicked Edge
Sharpening broadheads with a Wicked Edge precision sharpener depends on the type and construction of the broadhead. This guide breaks down which designs are compatible and offers tips to get the best results with your sharpening system.
Sharpening Two-Bladed Broadheads
Two-bladed broadheads are the easiest style to sharpen using Wicked Edge systems. These designs typically feature a flat bevel and simple geometry that align well in the sharpener’s vise.
- Compatible models: Silver Flame, Zwickey, Solid, and similar two-bladed styles
- How to sharpen: Mount the broadhead like any standard blade. Ensure the bevel is aligned and flat against the stones, and proceed through your normal grit progression.
Sharpening Detachable Three- and Four-Bladed Broadheads
Three- and four-bladed broadheads can be sharpened if—and only if—the blades can be removed from the ferrule. These individual blades often have flat bevels and can be treated like standard knives.
- Compatible models: Muzzy and other broadheads with detachable blades
- How to sharpen: Remove each blade from the ferrule and mount it securely in the vise. Follow your standard sharpening routine with attention to maintaining a consistent bevel angle.
Broadheads That Cannot Be Sharpened
Fully integrated broadheads with three or more blades molded into a single ferrule—like the G5 Montec—are not compatible with Wicked Edge sharpeners. Their fixed, multi-faceted geometry makes it impossible to mount and sharpen accurately in a guided system.
- Examples: G5 Montec, other one-piece, multi-blade broadheads
- Recommendation: These broadheads are best resharpened manually using files or diamond paddles, or replaced entirely if dull.
For best results when sharpening broadheads, always check whether the blades are detachable and can be mounted flat in the vise.
Learn more about our Wicked Edge precision sharpeners here.
